Quick photoshop question...
2 Mar 2004
Shropshire
Guys,
making myself a sig in photoshop, have made one with some snippets of bits and bobs on a transparent background. Which I was hoping would just show the snippits when its on a forum for example. Unfortunately though the snippets do show, but there is a horrible white background..showing the size of the signature if you know what I mean.
I was thinking if I created a file with the tranparent option selected the background would be just that, transparent..
I guess I've done something wrong, but just not sure what and couldn't see an option or anything.
So any help appreciated.
Cheers
Transparancy is a bit iffy to say the least, you could use a png. But IE doesn't support it with transparancy. You'd have to use a GIF. and still set a matte colour thats like the background it'd be used on.
bigbadish said:
Guys,
Cheers
I get the same problem with P'shop Transparency and saving as JPEG's.
The workaround i use is to substitute the transparency for the exact match of the backgound you are overlaying it on. ( If that makes sense ).
Example ;
I matched the Blue background from the forum to give the appearance of transparency around the above sig.
Hope this helps.
Mark
Okey dokey, thanks for that I'll have a bash :)
I tried it without doing anything colour wise...the result
seems to work ok, which is good hehe.
I'm using Photoshop CS if that makes any difference.
Cheers
Thats because jpegs don't support transparancy, you'll need to save it as a .gif or .png
Nearly didn't recognise you there with your new shiny Wise Guy avatar. :)
Cheers
Looks great , nice job. :D
Mark
