lol, will it still work?fatiain said:Drill a few holes in it to make it lighter or fill the envelope with Helium.
secretspy said:ok firstly - you're trusting the royal mail????? to deliver by tuesday?? wow your brave!!!
secondly - check royal mails webpage.
secretspy said:you must have some food scales???there is also a cost calculator on the website, where you select the place your sending it to and also they give an example of items in case you dont know the weight
then it will tell you how much
spike's said:lol, will it still work?
Lagz said:I've posted CDs with just 1 first class stamp and it has arrived fine. I'm guessing the card weights a bit as well, but it should be OK. Having said that, you may as well just stick 2 stamps on to be sure.
Stick 3 on thenspike's said:exactly i think she would be royaly ****** if she had to go and pick it up.
at this rate it may be easier to hand deliver it.fatiain said:Stick 3 on then![]()
Rather than trust Royal Fail, yup!spike's said:at this rate it may be easier to hand deliver it.
only thing stopping me is 130miles.fatiain said:Rather than trust Royal Fail, yup!
still only 3 weeks 3 days till i see her again. then its 5 days together.
