I`m looking for a PSU to replace one that has blown at work (IT are not qualified for such things). The machine is an older P4 unit that uses 3 points for power - the standard ATX and small head (4?) connectors, but also an 8 pin single line flat connector. I`m not sure of the correct description to locate the appropriate product on the web, and so was looking for help....
Cheers.
Cheers.
