Quick PSU question
11 May 2007
Hi
Just got one of these power supplies
http://www.overclockers.co.uk/showproduct.php?prodid=CA-023-OC
I wanted to check it's OK but haven't got my new motherboard yet. Can I turn it on without plugging it into anything or just plug in a couple of the molex connections into my case fan controller and temperature display to check it works.
Will that be ok or might it blow up if it's not connected to a motherboard?
Incidently I didn't get it from overclockers but it's the same model as on overclockers but the specs are wrong as they were on the site I bought it from.
There is only one floppy connector and 5 molex connecters and I haven't a clue what "OCZ ConnectAll™ universal connectors:" are.
Thanks
Pete
Look here.
You will need to join that forum to see the pictures.
Take great care tho, as they dont show your model.
You also need a DMM to do it properly.
