Quick Q about "display port" connections
28 Oct 2002
Hi
The Dell monitor i am thinking of buying has 1x Display port.
The graphcis card i have (hd 6950 oc twin frozr iii) specs says it has 2 MINI display port connectors.
Are these one and the same thing?
thanks
They're the same thing just using a different sized connector.
You'd need a miniDP to DP adapter and then use a DP to DP cable.
Or you'd need a miniDP to DP cable.
Or just use DVI (dual link if the resolution is greater than 1920x1200).
