Hi!
Having just bought 2Gb RAM which is now sitting nicely (touch wood) at DDR500 speeds, I'm having another play with my PC. At the moment I'm at 2.5Ghz, 250Mhz fsb, DDR500 (3,4,4,8).
I know my chip can do 2.8Ghz, but as 10x is my highest multiplier I'm limited to fsb clocking only and using a mem divider. Currently I've got the HTT multi at 4x giving me a round 1Ghz. If I up the chip to 2.8 and lower the HTT to 3x (3 x 280 = 840, necessary as far as I remember), what impact is this going to have on the performance? I think I'm also going to have to run my memory at 232Mhz, although of course I'm going to push for the higher 256 offered by the next divider. If it's at the lower speed I can always try to tighten up the timings.
The PC has been running Orthos for 15 mins now and seems fine. The performance is good at stock, don't get me wrong, but I can't settle for that now can I?
Thanks!
EDIT: Damn, I forgot how addictive this actually is. I've been benching fine at the above settings but I can't get the PC stable at 2.8 whether I use the 183:200 or the 166:200 divider. I've tried higher voltages, but I don't want to push my luck too much this evening. Will try again tomorrow.
Thanks!
