Quick Q about xbox 360?
23 Feb 2004
Brentwood, Essex
Hi,
I dont have a HDTV but I do have a EDTV and the maximum resolution it can take is 576p or 480p and also has component connection on the back. Would the xbox show up on the telly? as Ive only seen 720p and 1080i.
thanks
You can set 480p in the display menu using the component cable (if the slider is set to HDTV)
Whether or not it will display on your tv is another matter, no idea I'm afraid!
