Quick q. on "daisy-chaining" network
11 Jan 2005
London
Not sure if daisy-chaining is the right word to describe this but -
I currently have a 1 port modem/router connected to one of the 2 ethernet connections on my Asus A8N-SLI. Can I use the other ethernet connection on the board to connect to another computer ie like a daisy chain, or do I hit problems because they're different types (nvidia and something else)? Obviously want the router and both computers all to be able to see each other.
Thanks
You could do it that way, but it would be much easier to buy a cheap switch and connect that to your router. Then plug the PCs into the switch.
Hmm, seems to be quite a difference in price between a simple hub and a switch. Will a hub pass through gigabit ethernet or act as a bottleneck?
Not sure it's worth paying £30 if using both ethernet ports on my main computer will do the job. What do you reckon?
The switch will be worth it. Without, you have to make sure the PC with two NICs is always on. Not to mention the amount of hassle you'll have bridging the connections - that never seems to go smoothly.
Both good points. In that case I'll look in to getting a cheapo gigabit switch. Alternatively I could go wireless and buy a new wireless modem/router. Rule of thumb, what sort of speeds could I expect. Fast enough to stream an xvid from one computer to the other?
Streaming XviD can be done on wireless - it only needs a few Mb, something Gigabit far exceeds.
