I haven't begun to overclock, I am just on the task of lowering some frequencies. Yet I get some disparity between software readings.
Which software should I trust? Albeit you would think both the Gigabyte bios and Task Manager should give the same performance readings, that they don't.
What software do you use for perfect trusted readings for OC and under~clocking? Do you trust Task Manager at all?
Here's a screenshot.
