Quick Q.. re: led case mod lights
You would be much better off getting a Light strip rather than individual LEDs.
You could connect them using a 3 pin fan hub if you really wanted 10 of them.
Similar to this. (this is found on the NZXT H630 case) altho I'm sure you could find one sold on it's own.
Ok thanks very much. Actually I think 20 is too many, I might go with the light strip or just 3-4 LEDs. I've seen 3-pin splitters that give you 4 connectors.
