Quick Q...
why would it be a bad idea? If its a sealed loop (which it should be otherwise it'd be leaking :p) mavity makes almost no difference. Might just make it a tad harder to fill.
Ok, sorted it now, just drilled 2 holes where extra HDDs are meant to go and mounted it there, got everything linked up and flowing good.
Just another quick Q... :)
I have this reservoir, XSPC 5.25 drive bay. The only problem is that it came with no documents and the website doesn't have a manual so i don't know which is the inlet and which is the outlet hole... so i guessed.
Can anyone shed some light or doesn't it matter which holes are used for which tube?
Thanks
jellybeard999 said:
so long as it doesnt draw water against mavity its ok
have you read the rest of the thread? Don't talk nonsense, a pump can easily draw water against mavity because its pushing it out the other side. mavity has next to no effect.
Unless its brand specific, but id assume it is the same for all pumps, what with thew similar design and all...
Laing say dont do it
Voids warranty with certain manufacturers
Google upside down pump and its a general no-no
Do you not mean the way the pump is mounted rather than working against mavity?
I had my D4 mounted near the top of the case with no problems.
Thanks for the replies... sorted the pump and sorted the RES. Another quick Q... :p
Would the default fans which come with the Gigabyte 3D Aurora be sufficient to cool 2 GPUs and a CPU on a Thermochill double RAD??
Thanks again
