Quick Q
Theres a few things you can use to get various temps, though not sure any of them specify RAM, why you after RAM temp specifically anyway?
Try coretemp to monitor CPU temperature
GPU-z will give you your gfx card temp
speedfan has a few different temps in it
thers no specific software that monitors your ram temp mate..
just have a touch after it has been running a while, shouldnt be too hot to the touch (when pc is off obv)
why are you wondering about this may i ask.? :)
OC or something.?
