Quick Q
Permabanned
3 Jan 2009
Derby
I was just looking at the Broadband Line Status and I see I have a lot of Noise.
  • Statistics Downstream Upstream
  • Line Rate 3776 Kbps 448 Kbps
  • Noise Margin 15.1 dB 21.0 dB
  • Line Attenuation 51.0 dB 31.0 dB
  • Output Power 19.2 dBm 11.8 dBm
And every time I go to do a speedtest at http://www.speedtest.net/ it don't work.
It like get to about 1MB and then it just stop and wont move on to upload or any thing.
Is they something wrong with my Internet?
All so I see some one is connected to the Internet
192.168.1.2 00:1A:92:24:96:0C br0 Dynamic
How can this be when they is a password on the Internet?
Asus is a make of computer hardware. That MAC address belongs to a machine that is made by Asus.
If you are on your computer now go to the command prompt and type in ipconfig /all and see what the physical address is listed as. If it matches 00:1A:92:24:96:0C then it is you.
Just did that, Not same as mine
