Quick Q6600 Question
LiE
LiE
Caporegime
2 Aug 2005
Milton Keynes
Not really into overclocking but I download CPU-Z and core temp to have a look if I had G0 stepping, which thankfully I do. Then noticed the core speed looks very low? I did try some overclocking many months ago but I believe I set it back to default. Here's a screen.
Thatll be intel speedstep c1e/eist. theese are powersaving features and are perfectly normal, put the system under a bit of load and youll soon see full speed:)
The pic wont be showing the proper vid as speedstep reduces the voltage when the system is idle, if you want to check the vid its best to disabe speedstep.
