fothsn said:Where is the GTA San Andreas User Files folder under Vista? in XP it was in My Documents I cannot find the folder anywhere![]()
Any help please guys![]()
fothsn said:Nope isn’t in My docs, totally puzzled here![]()
Lord_Kokain said:I just happened to stumble across the same problem tonight, after having installed the game for first time on my vista machine. Looked everywhere but didnt find the folder that used to stay in "My Documents" in XP.
What is even worse though is that when I try to run the game it gives me a message saying that I should remove the current disk and insert the original one(?!?). Anyone got clues on that one? I tried to reinstal but its the same effect.
Kipper67 said:Does Vista not come with a search function ?![]()
modo77 said:Its in documents on my install
fothsn said:Search? whats that
Not in mine it isnt, can find the folder anywhere crazy..
fothsn said:I can’t help you on your problem I haven’t seen that error before,does the game actually load?
