- 29 Sep 2004
Hi guys, just got a quick question for ya
whats the reference/recommended max temp for a 1950 pro AGP ? and if your running one what temps are you getting at the moment with what cooling?
the reason I ask is that over the last week I have noticed my card is running much hotter than it has been in the past, previously it would run around 40-45idle and 54-58 under load, now its more like 50-52 idle and anything in the regions of 70-80c when under load for a while
thanks
edit: have also reseated the heatsink/re-applied some Tuniq TX-2 to the gpu core since i noticed the temps but hasnt helped that much so far
thanks
