Quick Question - 6gb or 12gb
11 Aug 2009
Hi,
as stated, just a quick question -
Had my system as per sig for a year now - running nicely oc at 4mhz -
I use my system mainly for Video / photo editing ( HD stuff ) and keep an eye on the memory usage which rarely goes over 40 % - So, question is - do I need to keep the extra 6gb of my OCZ memory or can I safely sell it knowing that I'll never need that extra 6gb ?
Thanks for any replies
Foz :D
Sell it if your only using 40% of 6gb
What I did after initially going for 12gb and finding I wasnt using it
just take out 6GB and try your computer for a week or month, if you don't like it put the 6GB back in, if you find you're coping fine then try and sell it.
4mhz ? nice :D
