Quick question about HDTV running from a PC
15 Jul 2005
UK
Hi all,
I have bought the LE32R74BDX a couple of days ago, and notice that it has a old VGA PC input, also I noticed that in the manual it says you cannot connect the TV upto a DVI port
can you get a HDTV signal through a old VGA port? because I have some HDTV LOST and Prison break on my PC, and would like to see what the quailty is like
Thanks
-Rhys
Hi,
AS long as the TV supports 1280x720 (720p) resolution or higher over its vga connection then yep you sure can. In fact you can still watch it even if the supported res is only 1024x768 thats still better than DVD resolution :)
Cheers,
Steve
