Quick question about input/output security
2 May 2004
I've set myself a little project of creating a secure, efficient forum using PHP - I don't plan to release it or anything, it's more to keep what I know about PHP fresh in my head as well as learn more :)
However I have forgotten a little as I haven't coded in a while :p
Am I right in saying I should be using mysql_real_escape_string (I'll be using robmiller's quote_smart function for this) for data going into the database?
So for example when a user is entering something into a form I'd process his/her entry through htmlentities() - e.g. htmlentities($_POST['data'], ENT_QUOTES); along with quote_smart() in the query?
Then for reading from the database I'd just use quote_smart() in the query?
Thanks,
Craig.
I'd just use mysql_real_escape_string() on the insert and then htmlentities() when you select it and output it. No real benefit to storing it with entity encoding - in fact it puts you at a disadvantage in a case where you might not want to output the content to a browser, but instead to another medium where character entities will cause problems.
You also don't need to escape the data again, with quote_smart(), when retrieving it from the db as you've already done it once and you're not protecting against anything when you're outputting it.
Just sanitise the data against database injection (mysql_real_escape_string()), and then deal with it on the output. However it does depend on the context really - for performance you might want to do all the sanitising and tag stripping at the insert rather than the select (insert only happens once).
What about when I'm selecting information from a database based on the URL, for example:
PHP:
<?php
$id = $_GET['id'];
$sql = "SELECT * FROM table WHERE id = '$id'";
Am I right in saying the safe way of doing the above would be:
PHP:
<?php
$id = $_GET['id'];
$sql = sprintf("SELECT * FROM table WHERE id = %s", quote_smart($id));
Along with checking that the $id is valid of course (intval() etc.)
Thanks,
Craig.
