Quick question about mounting a CPU WC block?
17 Dec 2004
Crawley, WEST SUSSEX
Does the CPU have to have its IHS removed to fit a Storm G4 Waterblock? Or can you just mount it with the IHS on, as I have never removed one of these and knowing my luck will completely bodge it. Can i just yank off the xp 120 i have and put the CPU block on?
why would you need to remove the IHS, not exactly a good waterblock design if you had to :confused: .
Its designed to work with Athlon 64's as they are designed to work....with an ihs
Tom :)
Yeah just someone said in another thread that the alphacool nexxos block works well with ihs less cpu's and that got me thinking. But new to all this so thought I would check thanks.
i dont get removing the IHS its pretty pointless you only gain like 3 degress and it is a pain mounting a block on the chip as there is less to contact with and cracking the chip is so easy. i have removed one before and i wont doit again because i gained nothing from it except the occasional scary moment!
