Quick question about old PC
29 Jan 2010
London
Hi guys. I'm trying to OC my PC I have DDR2 667 5-5-5-15 at 1.8 I have 2x2GB and 2x1GB all running in dual channel. My mob is DG45ID from intel NO OC ON THIS MOB. Only thing I can change is 667 to 800, timings and voltage from 1.8 to 2.12. Can you help me out how to OC and to get this ram running at 800? Please don't post if you are about to tell me is not worth it. Any questions just ask.
check the current voltage/timings for 667...increase up to 2.1 to see if 800 same timings is stable....ddr2 up to 2.1 is i believe not a 'dangerous amount'.relax timings if possible on your board to see if they can achieve stability..then reduce voltage to achivieve optimum voltage/timing/heat balance..
also check if cpu bus changes when going to 800..there could also be a limiting factor here...if the cpu bus speed chaanges then there may also be some cpu voltages to tweak, again if possible on that board.
