Quick question about reaction kinetics [Chemistry]
18 Mar 2008
If changing the changing the concentration of a particular reactant doesn't change the rate, then it's zero order with respect to that reactant?
If you double that reactant, and the rate doubles then it's first order?
If you double that reactant and the rate quadruples then it's second order?
A simple yes will suffice if correct :p
Thanks
Wow! I have forgotten ALL my A-level chemistry! I recognised the question, but had NO CLUE what the answer was!
