Quick question about those little lcd readouts
Caporegime
18 Oct 2002
Ireland
Jus wondering how easy are they to install\setup and do they come with some sort of plastic plate so they can sit in a drive bay? referring to the lcd displays some people have in their drive bays that shows cpu speed, temp etc.
if you mean this for example they just fit in the 5.25" bay like a normal drive, and then plug the cables in, sometimes use external socket which requires supplied cut pci backplate.
Matrix orbital display's (which I have one of) can be bought with a prefitted metal surround for a 5.25" bay (or 2 bays), just screws in like normal. You have the option of external fitment via pci bracket and usb socket or for about £10 you can get a cable that fits to the header on the motherboard.
Yeah its the matrix orbital display. Im assuming theres sotware or something it comes with so you input what the pc has so it can display it?
Yes and Yes it uses USB and comes with drivers and software
sid
