Currently on a quest to get my OCZ plats to run at 1866 Mhz. Currently they are unstable past 1333 Mhz even with relaxed timmings.
My problem is that if I set the DDR voltage to 1.64 in the Bios and reboot - the display will show the voltage as 1.71 even though 1.64 is shown as selected - therefore untill I can find out more I have it set at 1.58 which corresponds to 1.648 in the BIOS display.
Anyone else have any similar experiances with motherboard voltages for RAM?
Obviously if 1.71 where the true volts going through the RAM I would not be too happy.
