You using Manual Voltage? what CPU, if you can run your CPU on lower volts and stable all the better.ng93 said:Aye in overclocking guides they always have a recommended max voltage, which currently is what my voltage is set to in the BIOS. But CPU-Z is just over 0.1v under this (I guess that's vDrop?) so was wondering whether it would be safe to set my BIOS voltage to 0.1v over the max recommended. Thanks
I've got no experiance of using offset voltage with any motherboard as I've been with AMD for a few years and my board doesnt have the BIOS feature, but you could also read up on that and try using it.ng93 said:Manual voltage, 2500K on P67a-gd53, 1.35v in BIOS, 1.336v in CPUZ, 1.17v VCCIO, 1.185v VCCSA, 1.9v PLL. Just trying to squeeze some extra mhz out of it (gets to ~10mins in Prime 95 at 4.6Ghz, then crashes), but don't want to damage anything, this processor needs to last 18 months and I don't really wan't to be buying a new one.
On a side note my fan controller just broke so dropped down to 4.4Ghz at 1.3v for now to keep temps down as i've disconnected a couple of fans which are way to loud without a controller.
Have a look here: http://www.overclockers.co.uk/showproduct.php?prodid=CP-360-INMy motherboard apparently doesn't support offset voltage. But anyway i thought that that wasnt really a problem as AFAIK having a high idle voltage won't damage anything? Just wanting to increase the voltage so that CPUZ is max recommended but BIOS is > max recommended if its safe? TIA
Edit: just seen your last post, haven't tried auto voltage, didn't want to try that and for it to put dangerous volts through the chip, or would it stick to safe?
***OVERCLOCKING GUIDELINES***
- Do not exceed 1.425v core voltage, doing so could limit lifespan of the CPU
- Aim to keep temperatures below 70c underload if at all possible
- Do not overclock with BCLK, again doing so could limit lifespan of the CPU
- Recommended memory voltage is 1.50v, so make sure to run your memory at 1.50v, higher than 1.60v could limit lifespan of the CPU
- These recommendations come from OcUK and Intel, your warranty is un-affected but we highly recommend you adhere to the above to make sure your CPU lifespan is un-affected
- All Sandybridge CPU's worldwide should be run at the above or lower voltages, no higher!
I'm not sure but if you look in other forums like overclock.net and even on the MSI forums people are saying 1.4v is fine, at the end of the day best to find your best clock at lowest volts.ng93 said:Oh i've been hearing 1.35 as the max for 24/7, but then again they were old posts/threads, is this higher voltage a new thing? TIA
