- 31 Aug 2007
Hi all need a bit of advice. Im going to cut a blow hole but unsure on the best way to mount the fan. Ive read you can use a very strong epoxy to glue some M4 bolts to the inside of the panel and mount the fan that way to make it look sleaker/nicer. How is this compared to using screws through the panel?
Thanks all.
Thanks all.
