Quick question: Can I add an passive subwoofer to my existing setup?
27 Dec 2006
Northampton
Having a further read on google, I was also given an external amp. Would it be best recommended to have this connected up and then it hooks up to my main AV amp?
You have no way of setting the EQ and delays for both subs, you might find yourself in a position in which the bass is worse than when you started, particularly if the subs are of a different design.
In summary, its probably not worth the effort.
