Hey guys,
My sister and her boyfriend got me a K&N 57i highflow intake kit for my Focus as a birthday present. Not something i would ever of bought but it would be rude not to fit it. We had a go at fitting it but it started going dark and there was something we weren't 100% sure on.
In the instructions it says: "Carefully lengthen the flexi cold air hose and feed the hose under the battery tray. Pierce a hole in the top of the hose sleeve and secure the hose to the air box mounting bracket using a long plastic tie supplied"
The hose i have got with the set doesn't appear to have a sleeve, its a single skin metal flexi tube. I'm not sure i should be piercing this? Has anyone fitted one of these before?
