Quick Question For Prank
22 Oct 2005
Moving...
Is there a way I can add an icon to the desktop that when clicked will change the wallpaper on the desktop to something else?
i.e. I create a new icon that looks exactly like the my computer icon but when I click it it changes the wallpaper to be a fat naked bloke or something?
Your help will be for a good cause :D
**edit** - It will be on vista if that makes a difference.
Go to youtupe and put in icon pranks. there is one where you create a new icon and it will actualy force the system to shut down and display a message.
You can also change the icon so that they think they are going on the internet but its this new icon you have created, then all you need to do is put the icon in a memorable place.
Youtube is your best bet pluss you can read how its done
