Quick question (molex on mobo?)
19 May 2005
Lancashire
Hi,
I'm building a PC for my dad using a Foxconn NF4SK8AA motherboard and a single 7600GT gfx card. Ive just noticed theres a molex on the mobo above the gfx card slot. Ive never come across this before when i built my 2 previous rigs and I'm not sure what its for. Is it for if your running SLI?. Will i need to plug a molex into it if I'm only using a single card?.
TIA
Mark
May be extra volts for cards or for memory/cpu, you best to look at manual or if not got one, download as .pdf, normally these sockets are special shaped not molex but I have seen GPU's with molex even though they were newer PCI-E cards and it was not for fan as cards were passive where as PCI-E should have been enough to feed card power as its higher than AGP.
Thanks for the reply, ive got a manual and it says:
"AUX PEX PWR Connector: PWR2
This connector is auxiliary power which mainly supplies 12v and 5v power for the motherboard."
This is a pic of it.
plug it in.
it wont hurt, it can only improve stability
The PCI-E slot can provide upto 75w. thats a lot to ask from the ATX connector, on top of powering ram and all other mobo devices. so some boards have a molex todo this job.
It's to provide extra power to the PCIe slot for graphics cards that don't have built-in power connectors. Exactly like the 7600GT, in fact.
