the game runs but for some reason it doesnt look like its running smooth as it should be like in buildings it runs fine its only really in open world areas i get this problem.
have been running this game on high in eyefinity 5760x1080 with an x6 1090t 8gb ddr3 and a single 5850 @ 1000 core. So far its been good but ive only put a short amount of time into it due to needing modified config files for pitboy, lockpicks etc...
What kind of performance issues are you having with it?
The mrs bought the retail version which forced a steam install, enabled the display group and opened up the game and all my eyefinity resolutions were there (bezel corrected and non)... simply started it in an eyefinity res and away I went. Am using 1x Samsung 2333SW and 2x Samsung 2333T monitors.
I have been reading around and apparently 4 or 5 changes in the config will make the pit boy and other in game menus readable.
OP, details are in your sig, and point to you not having a GFX card, I don't see any reference to a card in your OP, what GFX are you using?
yeah make sure its patched.
Its the Steam version so it will automagically patch itself.
. but yeah of course if its steam it will be fully patched. also try defragging the game cache as steam suggested that when I 1st ran mineIt's a Steamworks game, you can't use it without Steamhe's not said that in this thread. but yeah of course if its steam it will be fully patched. also try defragging the game cache as steam suggested that when I 1st ran mine
It's a Steamworks game, you can't use it without Steam![]()
