Quick question on moving to fibre (at last!)
31 Jul 2004
Surrey
Right, just finally got confirmation I can get fibre so I'm all over it like a cheap suit.
2 questions..
1) My main phone point is in a storage cupboard with no power socket, is that an issue? How could it be fixed? (I rent BTW but sure I could get a line stuck round the outside of the flat, the landlord is pretty easy going and I'll do whatever it takes!)
2) I guess I have to get MAC codes etc? I have my phone line with the post office and broadband with whatever is left of BE since they were bought by SKY.
Thanks!
You will need power to connect the BT OR modem but the installation Engineer may well run in some extension cabling for you.
As for MAC codes, yes you will need to migrate your services from your current provider.
