Quick question on USB power
3 May 2012
Wetherspoons
I wasnt 100% sure where to post this, this seems the most appropriate.
Do PC usb ports have appropriate surge protection?
Basically, the reason I ask is I want to make a DIY made device, basically something that spins a motor, powered by 5v DC USB output of a PC. If for some reason, the motor fails, or shorts etc, is there any chance a VERY cheap electric motor could damage a pretty expensive PC?
Or even more basic, if you take the DC output on of a PC USB port, and short it, what happens?
If you short it, your PC will either shutdown or hang then shutdown. If your plugging in DC motors makes sure it has a soft start on it as the high inrush current could trip the fuse built-in the motherboard or the sensor in the PSU.
Polyfuses will prevent damage, but they don't reset reliably; if you subject a USB port to repeated overloads, you may find that it ends up in a permanent high-impedance state.
It is possible to fry a PC via the usb port. It was demonstrated on LTT a while back. Basically the USB stick sent a massive pulse back into the PC and fried it, killing the board instantly.
If you're worried, then spend a few pounds on a cheap powered USB hub that can a) supply lots of power down a port, b) take the hit if the motor does fail
