I want to install a Scythe Ninja 2 on this board, but using the bolt through kit means I will need to remove the northbridge heatsink on the rear of the mobo.
I know the mobo's manual actually tells you how to do this, but I am still slightly concerned at the idea. Has anyone here done this and had any problems, and if so were you running your CPU at stock speeds?
At this point I would be happy to leave the system at stock settings if it means I can get this damn heatsink on and quiet my system down a bit.
Thanks in advance.
Thanks in advance.
