Quick question re hair and face products
6 Jan 2006
Newcastle upon Tyne
What does everyone use to style their hair? I use fish of soho styling clay at the minute which is great but Ive recently restyled my hair a bit and need a bit more hold in the back so it sticks up a little more.
Also, what do you use to wash your face? Ive been using Simple face wash for a while and I keep getting a few blemishes so thinking of changing
Mark
I use garnier fructis gel when my hair is short and garnier fructis surf gum when it gets a bit longer. I chop and change for no real reason but this has been the combo for a while now.
Don't wash my face with anything, just stick it under the shower each day. Don't get troubled by spots, maybe once a month I get one or two but that comes after over indulging in booze.
I use Redken for Men rough clay no.20. Its about £10 for a small pot but it definitely works, particularly on shorter hair styles. It holds well and doesn't leave a wet look like gel does.
For the face, I sometimes use some Dermalogica Ultra-cleansing face wash, but not every day as I don't really need to.
I used Tigi bedhead manipulator(fibre gum) to style and tigi bed head maxxed out(spray) to hold it. The only product I've found to come close to that is fudge, but the Tigi stuff is great. For face I use L'oreal men expert vitalift, I haven't really tried anything else in that area.
Ah good man, Tigi Bedhead and Fudge are good stuff, much better than the average highstreet products.
By the way, if anybody here actually wants to buy any of the stuff mentioned or just any hair/face/body products I'd recommend mankind.co.uk. Its a brilliant site for all that kind of stuff. A lot of the things on there are pricey but well worth it imo.
I personally like to leave my hair unwashed for several days, at which point the grease build up is sufficient to style the hair by itself.
