I think they are all very similar so you shouldn't blow anything up. I used to borrow my dad's charger for his Acer to charge my Toshiba and it didn't do any damage. The Acer charger was more powerful so the only difference was my battery charged quicker
Disclaimer: Any damage as a result of your laptop exploding in electrical fireball is not my fault.
Thanks for the advice guys, I was pretty sure it would be fine but thought it would be best to double check, I will check on the labels to see what the power setting are as well.
