- 4 Dec 2009
- Worcestershire
Hi,
I have a quick question regarding ETTL using a flash (both on camera and off camera using the build in wireless trigger on the 60D). To determine the correct flash exposure does the camera evaluate the scene and decide how much flash light is required based on the ambient light for a correct exposure or is there a pre-flash before the proper exposure to determine how much light will be needed from the flash?
The reason I ask is to try and determine whether the camera will factor in the fact that I am bouncing the flash when using ETTL or whether the camera is assuming my flash is pointed directly at the subject.
Sorry if that doesn't make sense. If it doesn't I will try and reword it
Thanks!
Thanks!
If you put the flash on camera and set it to a long shutter speed and rear curtain sync you should see the distinct pre-flash and actual flash happening. You can also use FEL to "pre-calculate" the flash power, although this also (on the 60D at least) exposes "correctly" only the centre part of the image so you may need to recompose after locking the flash exposure.
