28 Nov 2008 at 19:34 #1 regulus regulus Soldato Joined 18 Aug 2006 Posts 10,061 Location ChCh, NZ Is it an accurate representation of your FPS? Does Fraps itself chew away some frames?
28 Nov 2008 at 19:40 #2 Memphis Memphis Soldato Joined 13 Jan 2004 Posts 12,197 Location Inverness Of course it will reduce the framerate, as it requires some processing power to encode the video.
28 Nov 2008 at 20:02 #3 regulus regulus Soldato OP Joined 18 Aug 2006 Posts 10,061 Location ChCh, NZ So how big a FPS hit would you say it is?
28 Nov 2008 at 20:04 #4 silversurfer silversurfer Soldato Joined 13 Jul 2004 Posts 20,356 Location Stanley Hotel, Colorado The simple counter is accurate enough. If you compare it to the games normal fps measure it should read the same If you record video while playing it will fall
