Quick question regarding porting numbers
28 Jun 2006
I am changing from Virgin to Vodafone. When I receive the Vodafone sim card do I need to use that and have a temp phone number or can I use my virgin sim card and then after a few days my Vodafone one will take the number?
How does it work?
Thank you :)
Once Vodafone has your PAC code they will give you a date when the number wil be ported, you can continue using your Virgin mobile number.
On the day of porting you will loose signal on your Virgin phone, give it a few hours then hopefully you should have your number ported accross.
Hope the above helps :)
