- 22 Mar 2009
- Cornwall
ok, so had a phonecall from a friend saying they cannot get google.co.uk to work. all other sites work fine though. they have tried on their laptop, 2 mobile phones and 3 tablets, none will display google or youtube sites or apps.
if you ping www.google.co.uk it receives all 4 packets ok, and if you use the ip address provided when pinging it displays the google page fine and you can do searches as usual.
i havent been there to look at it, doing that in the morning, just wondered if anyone had any ideas what it could be and what i should be checking. i thought swap the router to eliminate that, cant see it being virus related as there are devices using windows, android and ios with the same problem.
they have tried both google chrome and IE on the laptop, both display 'your version of flash player needs updating' or something similar, yet when you go to adobe to download flash player it says you have the latest version. again, making me think its viral, but the tablets/phones connect to youtube and google fine when going via 3g, so again, makes me dubious it is viral.
