- 22 Aug 2005
- Clydebank
Hi all 3 questions i hope you BMW people can answer me with
m140 with adaptive suspension(i think??)
any way it has the button to change from sport to comfort and sport +
so sport makes the dampers more firm and makes the engine a 'bit more sporty'
But, pushing the gear stick to the side also makes the engine a 'bit more sporty' And I can press sport and push the stick, or push the stick only, or push the button only.
1. What is the difference between the 4 possible combinations ?
1a. Also, for a bonus, is there any difference between sport+ and sport except the traction thingy? I defo feel like it's even more aggressive and more exhaust burble...
2. I like the heavy steering and improved throttle response when i press the sport button. But i'm not keen on the firmer sus -- is there anyway to make the steering heavier, (and the nicer throttle) but keep the suspension soft?
3. a. related to 1, but does sport mode or S mode literally put more fuel in the engine -> more power ? So it's less economical than comfort even if driving at normal speeds (40-60 mph) ,
3b. conversely if i cruise at 70mph on the m-way. Does it matter a diddly-squat what mode i'm in ? as same speed, --> same economy? Sometimes I like to just leave in in manual, in 8th on the motorway as it can be really aggressive when overtaking, like a auto downshift and max power when I just want a gentle pull in top gear, it's got the torque for it for sure.
Many thanks
Many thanks
