Link doesn't workArthalen said:
R B CUSTOMS said:Compression fittings dont really take advantage of PTFE tape on the tubing end, although its useful where the fitting fits into the acctual RAD, or block, then again thermal take stuff is well well fitted into the components so PTFE is rarly needed. they only tend to leak at the tubes dues to user errors, not fitting the tubing correctly
on a side note, its best to cut about 10 CM of PTFE tape and wrap it in the direction iof the thread ( clockwise looking at the treaded end) length depends on the size of the barb etc etc, but 1 -3 layers is enough.
thats only for future reference
its about 60pence a spool i think
Stelly said:I know that this is a little off topic but when I come on the forums and see that R B Customs has posted I get a little excited that you might of posted some more piccies of his custom rig
Stelly
theres been an update to my thread u may have missed.]R B CUSTOMS said:lol my first fantheres been an update to my thread u may have missed.
btw Arthalen, are you havving any bother with any leaks or anything :S? just wondering why your asking to find out ?
Arthalen said:@RB - Not got the kit yet, just remember reading some had this kit on the forums and recommended PTFE'ing the connections.
PS - Where's the thread - love to see the setup RB![]()
