Quick Question...
10 Nov 2006
Forgive me if i'm being completely stupid, but i cannot for the life of me figure out how the fan controller included with the TT120 fits into a standard spare PCI space. It's far bigger in comparison (taller) than the standard plate that i've removed. At what speed will the fan run at if i disconnect the controller? I'm having to run my PC with the side of my case off at the mo. Anyone care to explain?
Thanks!
with it removed it will run 100% by default, though most modern motherboards will allow you to set it to increase with temp from the BIOS, essentially making fan controllers a bit pointless, apart from being able to adjust manually ofcourse
