Quick question.
You are a n00b dude. Why do you keep posting stuff on here when I tell you "it's ok" or "you won't blow it up" :p
Especially for little things like this. It's self adhesive. So go figure :p
Well as it is not a solid surface ie full of holes didnt think self adhesive would be very effective. :o
I used superglue to stick a 16v badge onto some mesh once. Took some getting off :)
Adhesive pads are usually very strong, even on small contact areas.
Plus, the speed of the car will push the badge onto the mesh... unless it can reverse at 150mph... then it might just peel off.
I stuck very similar badges on my Golf and 309 grilles in the past. Yes they stick just fine.
