Quick question...
7 Mar 2005
The Voice Of Football
I am currently trying to find out my cpu max. I have dropped the ram onto a multiplier and am slowly cranking up the cpu mhz. However, it is doing my head in booting back into the bios after each successful test (occt)
Is there any app that will allow me to alter the settings from within windows? Settings such as fsb and vcore in particular
I am running an DFI Lanparty SLI-DR and Athlon 64 3500+ winchester core.
Thanks in advance :)
No.
http://www.nvidia.com/object/sysutility.html
Adjust motherboard settings: Change system clocks, system voltages, system fans and memory timings.
Dynamic BIOS access: Change system BIOS settings without entering the BIOS!†
Improved dynamic overclocking: Provides on-the-fly overclocking and BIOS configuration within an easy-to-use Windows interface that is streamlined and simplified for better user understanding.
Improved system monitoring: Temperatures, voltages, and bus speeds are now available as an "always-on-top" window with a transparency option so that it is visible at all times.
Voltage and bus speed monitoring: Track actual motherboard voltages, GPU clocks, bus speeds, and CPU core speed to ensure safe and correct settings.
