15 Apr 2008 at 19:19 #1 GazNofx GazNofx Associate Joined 3 Aug 2007 Posts 70 What is the small little hole on the top left hand of my speaker called? And where can I get a replacement for a B&W DM602? Thanks. Last edited: 15 Apr 2008
15 Apr 2008 at 20:07 #2 Martynt74 Martynt74 Soldato Joined 20 Feb 2004 Posts 24,229 Location La Romana, Spain Its just a hole for the speaker grille to fit into. There should be on on each corner
16 Apr 2008 at 10:19 #3 GazNofx GazNofx Associate OP Joined 3 Aug 2007 Posts 70 They have a name though don't they?
16 Apr 2008 at 10:22 #4 Hedge Hedge Soldato Joined 18 Oct 2002 Posts 19,603 Location Somewhere in the middle. Its just a speaker grill mounting point, dunno what else it would be called. is it a grille or the actually small circle bit you need?
16 Apr 2008 at 10:25 #5 -Ad- -Ad- Soldato Joined 4 Nov 2004 Posts 14,500 Location Beds Hedge said: Its just a speaker grill mounting point, dunno what else it would be called. Click to expand... +1 E-mail B&W maybe, but surely the grill will be held on fairly tight with *** other 3 corners anyway.
