Quick question....
6 Mar 2004
North Wales (Flintshire)
Does
Wireless Keyboard Yes- 2.4GHz
Wireless Mouse Yes- 2.4GHz
Mean it is bluetooth or have i got it wrong??
Thanks
keyboard and mouse connect via wireless interface
bluetooth is a (wireless) comms device normal used to connect mobile phone to other devices
The benefit of bluetooth is being able to use any peripherals on laptops for example without using a dongle.
Also you would be supplied with a bluetooth dongle which I assume you would use with your desktop, I assume this would also open up the ability to use bluetooth with other devices such as mobilephones etc (please correct me if I am wrong)
Well the trouble i have is the mouse and keyboard need to be away and higher than the base unit, So im needin something better than my other wireless keyboard and mouse i had a year or so ago which unless it was directly inline it would not work porperly.
Also the Keyboard and mouse will be at least a metre away.
