quick question
5 Feb 2009
N. Ireland
as per the title,
was looking at HWmonitor and noticed that the +12v rail was only showing a nominal figure while the -12v shows round about -12v. just wondering why this is?
Same here, HWmonitor doesnt read certain settings on mine either, VIN1 which is supposed to be ram voltage, is displayed at over 1.7, i currently have it at 1.66.
Even the cpu temps and fan speeds are different according to whats used to display them.
cheers fellas, i'll maybe test it with a multimeter just to be safe, but i'm guessing if the 12v rail was running that kind of voltage shown in HWmonitor i wouldn't be sitting here typing on the pc!?
Thats right, your pc would not of started! checking with the multimeter will give a better idea :)
