Quick questions - Xbox HDD
28 Mar 2005
Newbury
Few quick questions regarding upgrading to the Xbox 120gb Hard drive.
  1. Does the standalone hard drive come with the data transfer cable?
  2. Are game licences linked to the hard drive or Xbox? Would I lose my licences transferring? I've already used the DRM tool this year.
  3. Does the drive you transfer from retain all it's data? or is it wiped in the process. I'll probably keep the 20gb for a backup.
  4. If I have any downloads running, is the progress copied or do I need to start again?
I need to know sooinsh as I plan on getting one later if it's all ok.
Thanks very much!
Cheers! I'm not to fussed about having to start downloads again, it's just a bit of a pain as I've only just started downloading Fable.
As long as the original hard drive is usable after it's wiped it's not a problem again. I'll be able to transfer most of the saves by MU.
Thanks very much.
