Quick RDRAM question
17 Mar 2003
London
Is it useless or can I use it when I uppgrade?
Have 1 gig (4x256) of it for my Asus motherboard with 2.5 P4.
Now thinking uppgrading motherboard and CPU. Will I need to get new RAM as well? If not what CPU+motherboard would you recommend?
Thanks.
if you are thinking of upgrading the cpu and mobo, then yes it will be pretty useles, ddr is now the new standard (soon to be ddr2)
